RE: where to put tape for the panel lines
It depends on the effect you want and how the real plane is build. Panels that butt together will require a very thin tape on the line to creat a "canyon". Panels that overlap will require wide tape against the line to create a "step". In both cases primer may be used to build up the panel. You could also use body putty for the step style.
Carl
