RCU Forums - View Single Post - Not Moving?
Thread: Not Moving?
Old 03-23-2007 | 03:47 PM
m4gikman
Default RE: Not Moving?
ORIGINAL: RobertHull
ORIGINAL: m4gikman
I am very well aware of the fact that i need to break in the motor before trying to tune it. The problem with my truck was that the carb was open ALL the way. i.e. it was open too far. All i wanted was someone to tell me HOW far it *should* be open not that i should break in the truck.
Thanks for your help...
im glad your aware of the fact witch means for the first 2-3 tanks you didnt try and give it ANY throttle now just do what TRD said and you will be just fine
Not *any* ?
CEN Manual:
Code:
 Step 12. Keeps the Engine Running
 A new engine may not idle smoothly until it’s correctly broken in
 (Break-in procedures found in step 14). Use the transmitter to keep the engine reved up just enough to keep it running. If the engine stalls you may need to raise the idle slightly.
