Hanger 9 J3
Just got mine, and would like to put a smoke system in it, and also set it up so I can switch to floats. I already have a TME smoke system. Will make home made floats per Chuck Cunninigham guidlines. Should I sheet with balsa before glassing floats? Should I just sheet on bottom? I going to try to glass with minwax polycrylic. (worked good on an electric foamy.) Are there any hardpoints in the rear for a rear float mount. Is a Evolutin .60 NT big enough engine? Any tips before I start.
NeArLy NoRmAl Al
