RE: Hanger 9 J3
I was planning on glassing, just wasn't sure if I should plank the whole float. Plans as of now, (subject to change) is to plank the bottom with 1/16 balsa. 2oz. glass on the bottom. Then 3/4 glass the whole thing. Thanks for your help. I'm planning to use stryo foam, the white stuff. When I glass foam I've started using Minwax Polycrylic. Is this as good as Z-Poxy?
