RCU Forums - View Single Post - Optic 6 setup for Blade CP pro?
Old 03-24-2007 | 05:56 PM
HeliTB's Avatar
HeliTB
Default RE: Optic 6 setup for Blade CP pro?
Blade CP /Optic 6
Function Setting - Values
Servo Setup
Ch1 (aileron)- Normal
Ch2 (elevator)- Reverse
Ch3 (throttle)- Normal
Ch4 (rudder)- Normal
Ch5 (gyro not used)- Normal
Ch6 (collective)- Reverse
EPA Ch1 Ch2 Ch4 110
EPA Ch3 R/D=100 L/U=125
D/R All 100
EXP Ch1 Ch2 -15
EXP Ch4 -2
T. Cut 0
R->T On R/D=+1, L/U=-1
Throttle CurvePoint 1Point 2Point 3Point 4Point 5
Normal ST1 ST2
0 100 100
Inh 88 100
75 75 100
Inh 88 100
100 100 100
Pitch CurvePoint 1Point 2Point 3Point 4Point 5
Normal ST1 ST2
20 5 20
Inh 26 Inh
45 45 45
Inh 60 Inh
78 78 78
Revo Mix All -20
Swash Plate Ch1 Ch2Ch6 +90+90+42
I played around with the Exp, PtCv and ThCv periodically, so they may be different later, but this is what I'm flying with now. I dropped my throttle curves a little bit in ID1 around center, but notice the red LED on the 4-in-1 stays lit all the time so I don't think it made much difference. It behaves just like all 100's because I don't think the stock 4-in-1 can "see" the difference between 100% and 90%.
These settings work with my particular setup, but I wouldn't expect to just pick them up and plug them into another heli as is w/o some additional adjustments.
Disclaimer: Again these were my settings, you will need to tweak for your setup. When making any adjustment unplug motors.
