RCU Forums - View Single Post - Walkera Vs. E-sky
Old 03-24-2007 | 08:47 PM
guru101
Default RE: Walkera Vs. E-sky
Pika,
You will need to buy a brushless ESC if you want to change to a brushless motor, brushed motors are DC current and brushless are AC with electronic timing handled by the ESC.
It is also recomended to use a lipo battery if you go brushless, both of these upgrades will offer you more power and efficiency with less total weight than the stock equipment.
I cant give you an answer on the choice of chopper, i have the Walkera 22E and the 36, both bird's have their individual issues, but for the cost of one you can't realy expect a bullet proof product. Sadly a lot of people expect just that, and when they find it is not the case they feel free to bag out the product because it wont fly, most of the time this is due to poor setup and it cant handle a pilot that continualy stick's it into the ground.
ORIGINAL: Pika007
Greetings, fellow hellicopter pilots.
lately iv'e been thinking on upgrading from 4 to 6 channel heli
i read a lot over here and in other sites, about these two companies
bottom line is- which will be better to take- the E-Sky honey bee CP2, or the Walkera DF35?
the DF36 is not available around here, so i have choice only between those two...
and also- if i buy a brushless motor for the e-sky, do i need more new equipment or can i just put it instad of the brushed motor and use as-is?
thaneks for any post replied O: need the answer A.S.A.P :]
