RCU Forums - View Single Post - 4*120
Thread: 4*120
Old 02-16-2003 | 01:57 AM
HavinFun
Default 4*120
Anybody build a 4*120 with a G23?
I’ll be building one soon and have a few questions:
Was firewall moved back? If so how much?
Did you mount G23 inverted / which position?
Was stock muffler used? If not which muffler?
How much of the cheeks did you cut away/off to clear the muffler & carb?
Where did you mount your rudder & elevator servos?
The G23 with stock muffler & carb is wider than the fuse. Have thought of just cutting everything forward of the firewall off but then it would look like a stick plane. Would like to keep as much of the cheeks intact as possible. Another thought was to widen the fuse forward of the firewall. Sort of like the cowl on a Cap 232.
Thanks for all replies.
