Originally posted by tailskid
Have a Saito .72 up front, well, sorta anyway...guess I'm in the market for a new Motor Mount...yep, mine decided it was supposed to be a two-piece mount!
And yes, mine was nose-heavy, so which LIGHTER mount should I be looking at?
Jerry
Hi Jerry,
When I built my US 40 I filled in the existing holes with 3/16 dowels, after using the supplied mount to mark some layout lines. Then I mounted a Goldberg universal nylon mount into new holes. The medium Sig mount would work well too. If you don't want to drill and fill the firewall then a Great Planes medium adjustable mount works. You will have to use the old mount as a pattern to drill holes in the Great Planes mount.
Cheers!
Galen
