Hey everyone, hope you all are enjoying the flying and/or building
I was able to accomplish a bit more this weekend, im excited as its getting close to being done. I'm also in the process of picking color schemes for it and am leaning towards transparent blue, some transparent red, and some white at the moment. Not sure exactly, but i thought being able to see the structure with covering on would be a good idea. Any suggestions or ideas on color schemes would be great to hear!?
Below are more pictures of what ive been able to get done today/yesterday and descriptions of each step. Thanks for checking out the build log.
(1.) CA'ing on the extra backing piece of the wing made out of the aileron stock. This piece is ca'ed to the back of the wing and sits up against F5.
(2.)Closer view of the wing on top of the fuselage. Showing the addition of both the extra balsa aileron stock pieces attached to the back of the wing. Sitting up against former F5 right behind them.
(3.) paper wing tubes for the servo wires.
(4.) Installation of the paper wing tubes. CA'ed them in place and tested the servo wire thru them to make sure they fit thru ok.
(5.)Adding the cap strips to the bottom of the wing.
(6.) Half of the cap strips on the bottom of the wing done :P
(7.) Addition of the servo mounting hardware in the wings. Each wing half will have a servo in it.
(8.) Completion of the cap strips on the bottom of the wing.
(9.) Servos in the mounting hardware that will be screwed into the plywood wing servo mounting pieces from step 7.
-David
