It's hard to say. Gearing and terrain play a part in it also. My son has a 16 turn in his Stampede geared with an 87T spur and 14T pinion and gets a good 15 minutes or more with a 3000 mah battery. I haven't timed it to be honest. The truck is basically stock. There again, it depends on how heavy you are on the throttle and the terrain. In grass it will be reduced and same with hill climbing.
ORIGINAL: johnny1333
if i run this setup, about how much runtime should i get?
17T double trinity monsters of touring
new brushes
6 cell 4200 mah battery
xl-1 esc
stock tires
that's about it, and running will b mostly offroad, and short burst of WOT
