runtime?
if i run this setup, about how much runtime should i get?
17T double trinity monsters of touring
new brushes
6 cell 4200 mah battery
xl-1 esc
stock tires
that's about it, and running will b mostly offroad, and short burst of WOT
new brushes
xl-1 esc
stock tires
This is a nitro forum
ask it here, you will get a lot more responses.
http://www.rcuniverse.com/forum/forumid_147/tt.htm
yes this is general mt forum
but most of the threads on here are for nitro
im just saying you will get a lot more information if you post in the other forum
they even have a thread just for stampedes.
http://www.rcuniverse.com/forum/m_2358901/tm.htm
FL
It's hard to say. Gearing and terrain play a part in it also. My son has a 16 turn in his Stampede geared with an 87T spur and 14T pinion and gets a good 15 minutes or more with a 3000 mah battery. I haven't timed it to be honest. The truck is basically stock. There again, it depends on how heavy you are on the throttle and the terrain. In grass it will be reduced and same with hill climbing.
ORIGINAL: johnny1333
new brushes
xl-1 esc
stock tires
new brushes
xl-1 esc
stock tires
FL
Ok, my son started out with the 4200 in his stampede and stripped the idler gear within the 1st minute of running it. So, I put the same pack in my rustler with a 14 turn motor, 17 tooth pinion, and 84 tooth spur and continued adding on to the time already put on the battery in the stampede with my son still driving. It ran 15 minutes before there was a noticeable power drop. By 16 minutes and 30 seconds it was slow enough for me to call it quits. This was pretty much full throttle the entire time.
Hope this helps.
Hope this helps.
