RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 03-26-2007 | 03:05 PM
  #236
JAS's Avatar
JAS
Default RE: Composite-ARF Integral, kinda build thread
The carb is low enough to be outta the way (unless it rotates more than 45 degrees [X(]) and the header has enough clearence. It doesn't move that much. You see that the motor is actually a bit to the left (from front) and can be rotated a bit right the help with that.
