I'm not sure what you mean by swashplate setting, but you will want to set it up as an aeroplane on your JR, and not a heli. This will just simplify all the setup. Hrm.. I was thinking that maybe you had the wrong type of receiver, but the blue arrow link that I found says it automatically detects the shift.... you need positive shift for a JR
http://www.buzzflyer.co.uk/product.a...ID=98&P_ID=339
I'm really not sure about the other stuff.... one thing is make sure the servo's are plugged in the right way.
here is something else I also found
This servo now uses signal-negative-positive "white-black-red" polarity that is compatible with new Blue Arrow, GWS, JMP and Wes-Technik receivers that use micro JST connectors for servo connection. It is not compatible with Cirrus Micro Joule or older (pre-July 2005) Blue Arrow receivers. To use these servos with Cirrus Micro Joule or older Blue Arrow receivers, you must swap the black and red wires.
If there are diretions that came with it... double check those and make sure you double check everything...
Sorry I can't really give you any good advice =(
