RCU Forums - View Single Post - Eflite Blade CX
Old 03-27-2007 | 07:56 AM
  #1312
dexon
Default RE: Eflite Blade CX
rayelljay is right - too tight could cause that.
But is rudder action doing ANYTHING?? (Throttle trim all the way down..... apply full rudder and *slowly* throttle up...)
I assume you remember to unplug battery before adjusting set screws on the 4-in-1.
When I have to adjust 4-in-1 from scratch, I start with a mid setting on
both srews...
If all else fails then a systematic process of elimination should do the trick. Lucky for you that you have
working helis to compare tests to.
Good luck.
