RE: Ultimate FX
when my mom gets home in like an hour i will get the pictures up. so i should put a little weight on the tail end. i hooked up the four ailerons now. i am using a 11.1v 1200mah but it only gets about 5 minutes on it which stinks. my elevator is about 2-7 degrees off. would that effect it. when i post my pictures look at the elevator and rudder are slightly angled. did anybody elses stick mount appear to be a little bit leaning to the right when looking at it from above.
