ys 110
I have a fairly new ys 110.Runs fine but due to an inflight breakup of the airframe (Thunderstorm encounter..LOL)The engine is now taking a rest.
I have applied the proper after run oil into the carb and top of engine thru the spark plug hole..and spun the engine.
But I have heard other problems result from these engines sitting around,such as the regulator clogging from old fuel still up in there.What do you recommend as the proper proceedure to avoid any dirt or clogging problems until I run it again.
Mike
