Troy,
I bought yesterday an 110FZ engine, to mount on a Funtana x100 and I have some questions.
1) The page with the setup instructions of the 110 fz (
www.ysperformance.com) is no longer accessible, and the new page (
www.yspartsandservice.com), doesn't have those instructions. Where can I find them?
2) You say to break in the engine rich. Rich in idle, mid range or full throttle? How many should the RPMs be during break in period?
3) You have said many times to check the valve setting at 0.003"=0.0762mm. How am I going to measure 0.08mm? To adjust them I have to follow the "tappet clearance adjustment", after removing the valve cover, as written in the manual?
4) Due to the high pressure developed in the system, do I have to secure the plumbing with "something"? If yes what?
Can I use a remote fueling valve? Or it won't stand the pressure?
Do you happen to know if the fuel tank provided with the funtanax100 is strong enough?
Thank you very much for your time.
