ORIGINAL: WalawalaStore
Hi,
I am using a WERKS clutch with NR PLUS 21-5T, I used it for once only and noticed that it works very good and fully adjustable. I got tired of those traditional clutch shoes and springs, difficult to install and uninstall even with proper tools. The shoes only wear very slightly after the main and wonderfully the 4 shoes can also provide a linear response, something close to 1.0mm springs with 2 composite shoes and 1 aluminum shoe. The clutch kit comes with 3 different types of springs and 3 types of shoes for your setup. I am using the black composite shoes, there are still telfon and rulon. Maintenance is simple because install and uninstall is really easy.
Regards
Joaquim
I just tried this clutch. I find after adjusting the nut. When driving the clucth seems to engage later evrytime. After inspection I noticed the adjuster keeps tightening itself. I used loctite on the tread. Did youhave the same problem?
