RCU Forums - View Single Post - New IR Combat Systems
Old 03-29-2007 | 12:06 PM
raimian
Default RE: New IR Combat Systems
if you can find a lens in a small enough diameter to use with any IR system you can tune it to create an accurate straight beam instead of the wide spread beams.
its just a matter of getting the lens the correct distance away from the IR led, there is alot of info about this on the miles tag optics page; http://www.lasertagparts.com/mtoptics.htm
