RCU Forums - View Single Post - Supervee 27 Floatation
Old 03-29-2007 | 08:23 PM
Orange Crush's Avatar
Orange Crush
Default RE: Supervee 27 Floatation
I might try that on OC before I retire that hull. I will glass over the hatch lock hole on the replacement hull I have on ready standby before painting along with the antenna tube hole in the hatch. I still utilize the oem hatch lock on OC and it does leak through it when inverted in the water.....not that I ever flip it or anything. Your idea will be an interesting experiment for me.
ORIGINAL: ctonez
On the cowl lock, this is what I've done to keep the water out:
cut a 1/8in. donut of silicone rubber tubing and stretch it over the cowl lock on the exterior side (carefully or with needlenose pliers...I broke a few stretching them over the lock).
you're basically makind a small O-ring to go on the outside of the lock.
When you press the locking mechanism, it still locks, but is snug and the pressure keeps a seal because of the silicone O-ring.
So far I haven't had any water in the boat since doing this.
I also use pool noodles and hatch tape. Always tape the boat!
Another great flotation idea I saw on another forum(I think...can't quite remember) was pingpong balls grouped and shrink-wrapped together...light weight & clean/cool looking.
