RCU Forums - View Single Post - Clamping help
Old 03-31-2007 | 08:11 AM
aerowoof
Default RE: Clamping help
those clamps look like overkill.I use spring type clothes pins for clamps as well as t pins or masking tape while gluing fuslage sides to formers.I also use x-acto bar type clamps and only use enough pressure to hold the piece in place not enough to crush.you may be able to remove those marks if you spray lightly with water let sit a minute then apply a hot iron.the steam should swell the dented areas as long as the fibers are not broken.repeat as much as neccasary
