The scoop is a little longer than it should be, but I'm going to leave it alone as I think it looks alright. Once its painted I'll check it again and if it stands out too much I'll trim it back.
Other than that, with the tail up the axles are forward of the leading edge, so landings should be easier.
I started another thread (
http://www.rcuniverse.com/forum/m_56...tm.htm#5646047 ) to see if I could get a response on which covering is better, Flite Metal or Metalcoat. Please pipe in if you have an opinion.
