RE: Clamping help
I use those clamps for work there way overkill,sometimes I will use them if I need to clamp hard wood or ply, try Home Depot or Lowes for the small plastic clamps they have a floating pad at the ends for a flat clamping surface there plenty strong for modeling.
usually I just pin the wood to a flat surface over wax paper so it doesn't stick to the surface or your plans.
