Magic Quality Problem?
Just began my Magic ARF, starting with the wings. Much to my surprise, I found that the precut holes for the servos where mismatched. One was 85 MM from the TE, the other was 105 MM from the TE. Based on the length of the control rods I’m assuming 85 MM is correct and I need to re-cut the other wing.
Does this sound correct to you guys who have built the Magic? Ask before you cut.
