RE: BME 115 Any Field Reports?
SS, you might end up pushing air out of the inverted vents. This may all depend on the type of baffling you are going to use also. With no baffling it seems that the pressure inside the cowl maybe greater than the ram-air effect from the two inverted vents, especially when the prop unloads in the air. I may be totally wrong here, but it is something to think about.
