Sheeting outer balsa wing panels
Only problem with that method is then you're gonna be sheeting all the way around the leading edge strip, trailing edge, and building up the ailerons, if you want to keep it all uniform. MUCH more hassle.
I'd go with Minn's method. Would be reasonable fast and efficient.
Heath
