RE: Jensen Ugly Stick Build
Well, not much happened here the last few days. I've been busy at work and a couple birthdays back to back! Time to get back because the flying weather is here!!!!!!!
I need a little help. I want to use a single servo with torque rods for the ailerons. I'm not sure how to do it since the ailerons basically attach to the TE. There is no place to "hide" or "hinge" the torque rod. Any ideas? I've always used them but usually the aileron is set inside the TE and the torque rod "hides". I've had a few ideas but they aren't very good. Does someone make something that would work like a hinge? Something that I could insert into the TE and it would "wrap" around the torque rod?
Sean
