RCU Forums - View Single Post - Reciever slots
Old 04-03-2007 | 08:31 PM
bruce88123
Default RE: Reciever slots
ORIGINAL: RCKen
Shortymet55,
The manual for this RTF package is available online, so you can read through it yourself. You can find the manual here; [link]http://www.hangar-9.com/ProdInfo/Files/han2600-manual.pdf[/link]
But to answer your question. The receiver that comes with this package is the [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=JSP30600]JR RS600[/link] , 6 channel receiver. This means there are 6 "slots" in the receiver. You will only need 4 of those for the servos in this trainer (1 aileron servo, 1 rudder servo, 1 elevator servo, and 1 throttle servo), plus 1 for the battery connection for a total of 5. This leaves one empty channel/slot in which you can plug your VoltWatch in to. So you will not need a Y-harness
Hope this helps
Ken
Oops Ken, If you look closely at the picture in the link you gave you will see the RS600 actually has 7 "slots" labeled ail, elev, throttle, rud, gear, AUX1 and lastly battery.
