RCU Forums - View Single Post - Evolution 46 Leak
Old 04-04-2007 | 01:06 PM
Celidon
Default Evolution 46 Leak
I have an Evolution 46 that I crashed last fall. It went nose first into the pavement. When I fired it back up on a new plane this spring it had a leak around the prop shaft at the front of the engine. I replaced teh front bearing but I still have a drip leak. Should I replace the shaft also? Any other ideas on wht might be causing this leak? The crank case does not show any cracks.
