RCU Forums - View Single Post - The best Blade upgrade is a programmable TX!
Old 04-05-2007 | 02:23 AM
mrasmm
Default RE: The best Blade upgrade is a programmable TX!
If you are so inclined and good at soldering, all you would need is the other receiver... this isn't a mod that most people can do though.
options
1. What you would need to do is get a 3 in 1 off of the blade cp prohttp://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLH1031
2. Edit: This will not work because the 2 in 1 does not have a way to turn off the revo for a HH gyro Get a 2 in 1 for the stock main motor and the stock tail http://www.horizonhobby.com/Products...rodID=EFLH1039 and a seperate gyro http://www.horizonhobby.com/Products...odID=EFLRG90HL
3. Or if you were going to go with a brushless main motor and the stock tail motor you would need http://www.horizonhobby.com/Products...rodID=EFLA311B the gyro from above and one of these http://www2.towerhobbies.com/cgi-bin...?&I=LXHUY2&P=7
