I think choppersrule said he had a fix for this... you have to open up the servo's and swap 4 of the wires around he said... and that will reverse the direction of the servos... If I remember right, you said that you just switched out to the hitec 55's?
ORIGINAL: ArrowNaughtic
Reversed the swash settings so the pitch works properly but sadly it causes the ELE to be reversed. Can't reverse the ELE servo as then it messes up the pitch function of all 3 servos. If you kow of a workaround for this, I am all ears. Until then, I am back to using the stock TX. (sniffles)
