RCU Forums - View Single Post - The best Blade upgrade is a programmable TX!
Old 04-05-2007 | 05:25 PM
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: The best Blade upgrade is a programmable TX!
Ok drphoto.....will be reinstalling the CNC head and the 6EXH.......... just wiped out my stock setup on the couch. Bent main shaft doesn't work to well............... will try to straighten it later tonite. If I may be so bold, If I have problems later with this 6EXH, may I pm you for some more advice?
I do have finless bob's thread bookmarked for building my TREX that is coming in the next couple days. I bought the spektrum package from helihobby.com and it should be here in town this afternoon.and delivered tomorrow to the house. I also bookemarked his HDX300 head setup as I wanted to use that for reference too. Getting a set of dial calipers on the servo links and lining up the servos made a huge difference. (had to change all the arm positions for the stock setup, will now change them back)
My main issue has been with the radio programming when using it. I get confused easily and forget to write all my settings down. I have the original settings written down for the HDX head, and will be using that for a new starting point.
TY drphoto......that actually was very clear and makes perfect sense.
__________________________________________________ _________________________________
Of all the things I ever lost......................................... I miss my mind the most!
