3Seabees Willow
I just got it so it hasn't been flown. It is WAY tail heavy and I am trying to find out if you are supposed to add a pound of weight in the nose. No luck so far. As to the flying wires mine are a b**** to install and you can't get them tight, I really don't see how they can be safely used. I am going to rig regular wires with turnbuckles to tighten. They won't look as scale, but neither does a pile of sticks, if you try to fly with the supplied ones. When you rig the wires tighten them for support....don't change any of the incidence in the wings. Also how did you hook up your aileron control wires?
