I have previous knowledge of how to taper dowels. I believe the technique is to use a hand plane or a sanding block to remove the wood from the end, very sparingly as you rotate the dowel simultaneously on a flat surface like a tabletop. Almost like whittling but removing minimal amounts of material at a time.
The rigging is, however, another question. Make sure you have some precision tool available such as tweezers and locking hemostats (like surgeons use). I find these indispensible for working with rigging.
ORIGINAL: azcaptain
What holds me back is not being sure of how to do the rigging and how to taper the dowels. The kit is great but instructions are VERY sparce.
Suggestions, anyone???
AZCAPTAIN !!!
