RE: World Models Super Chipmunk Setup??
I installed smoke in my cg pitts monster, my first smoke install. i used the sullivan skywriter pump, 8 oz tank, and a bme smoke nipple. I drilled and tapped the exhaust pipe close to the cylinder head and installed the injector. Some people wrap tubing around the pipe then into it for maximum heat, i didn't bother. i have the pump set on channel 5 at about 50 percent atv to get this smoke with my saito 150. Will smoke for 5 min. Just watch your weight on the chippie. I bet with full 8 oz tank, lines, pump and auxilary battery, you will be adding close to a lb.
