RE: Hangar 9 Pulse XT 40
I have a small hang up. The dowels that go in the leading edge of the wing were not installed. There were 2 dowels with the hardware however they are much larger than the holes in the wing. The dowels are roughly 1/4 inch and the matching holes in the wing are slightly smaller than 3/16. The hole in the fuselage is bigger than the dowel .
I can drill the wing and ca the dowels in however there will be a little slop since the fuselage holes are bigger.
Did anyone else run into this and what do you think?
