RE: Air Hogs Havoc Heli
those weighted tape strips are aluminum not lead , and the don't do much , place a very small safety pin, you know those small brass ones about 3/4 inch long and keep it closed ,the pin that is with the large part of the pin facing forward of the heli nose, tape it [do not stick it in the foam] or you will hit the battery,we don't want that, so TAPE it on the very bottom of the nose almost even with it where it ends even with the nose at the front ,center it on the heli s bottom and use only 1/2 in or 3/4 inch MASKING Tape , make it a short piece about 3/4 th inch long and it hold s very good ,now fly it and it will be like a new heli and go even forward in either a right or left turn.
