Gasoline Tank Vent Problem
I don't think a check valve is a gas system is a good idea. You would be amazed at the amount of pressure that can build on a 80 degree day when using gasoline, especially if the gas was relatively cool when it was pumped in. I think it not only may change fuel metering at the carb, but should it blow a line or split the tank it could be a disaster.
