RCU Forums - View Single Post - Gasoline Tank Vent Problem
Old 02-21-2003 | 12:26 AM
OUTCAST
Default Gasoline Tank Vent Problem
Originally posted by Flyfalcons
Filling the tank with gas not only helps minimize the pressure/vacuum buildup while in storage, it also helps prevent moisture from entering the tank and fouling up whatever fuel is in there.
I understand this and I agree with you, in fact I always parked my real aircraft with full tanks just for that reason. But we're talking about blocking vent ports with either plugs or check valves, and the more fuel in the tank the less room for expansion. We all know you can't compress a liquid so should it reach the failure point of the weakest link, whether that be a hose, the tank plug, or the tank itself, man is it gonna make a mess.
Please understand I'm not trying to start an argument, I just don't think it's a good idea.
