RCU Forums - View Single Post - Way nose heavy
Old 04-07-2007 | 03:27 PM
RAGII
Default RE: Way nose heavy
Oops! I may have been checking in the wrong position. After reading Minnflyer's post I decided to check the manual again. Now I need your thoughts about where they are asking me to check. The wing has a step in it, so I was measuring from the "straight" section of the wing. After looking at the diagram closer, I think I should be checking from the edge right at the side of the fuse. When I check it there it is almost right on (a little tail heavy) and my battery is at the back. I have attached several pictures and would like to see what you guys think. Thanks for the advice so far.
Rob
ID:	659109   Click image for larger version
ID:	659110   Click image for larger version
ID:	659111   Click image for larger version
ID:	659112   Click image for larger version
ID:	659113   Click image for larger version
