RCU Forums - View Single Post - Switching an engine from ring to ABC
Old 02-19-2003 | 09:31 AM
ShempHoward
Default Switching an engine from ring to ABC
From the ST documentation I have it does appear that you can convert a G61 ringed to a G61 ABC via the method you asked about. The specs they give for both engines are identical except the power ratings is slightly higher for the ABC at a slightly higher RPM. Better check very closely about this conversion before you spend the money. Give Hobby Services a shout and see what they have to say about it.
