RCU Forums - View Single Post - Way nose heavy
Old 04-07-2007 | 04:29 PM
Munkster's Avatar
Munkster
Default RE: Way nose heavy
ORIGINAL: RAGII
Oops! I may have been checking in the wrong position. After reading Minnflyer's post I decided to check the manual again. Now I need your thoughts about where they are asking me to check. The wing has a step in it, so I was measuring from the "straight" section of the wing. After looking at the diagram closer, I think I should be checking from the edge right at the side of the fuse. When I check it there it is almost right on (a little tail heavy) and my battery is at the back. I have attached several pictures and would like to see what you guys think. Thanks for the advice so far.
Rob
Well well well, doesn't that look familiar. Put the weight in the back of the air scoop. Works just fine. What engine you running in that thing?
