RCU Forums - View Single Post - CHUNK OUT OF ENGINE - PLEASE HELP
Old 04-07-2007 | 07:37 PM
bruce88123
Default RE: CHUNK OUT OF ENGINE - PLEASE HELP
ORIGINAL: MinnFlyer
BTW, When I said use JB Weld, what I meant was - Glue the original piece back in with JB Weld. Don't try to just fill the hole with it.
Clean it all good with alcohol first.
Once the piece is in place, add a blob of JB Weld on the underside of it for extra strength. Just keep the muffler side clean for a good seal with the muffler.
If you get some JB Weld on the seal, wait till it's cured and then chip or sand it off rather than try to wipe it off which could make the piece move out of place - unless you can easily clean it without the piece moving.
From post #1: "And no, I no longer have the chunk around so it is not available to reattach."
