RCU Forums - View Single Post - Throttle trim hover advise
Old 04-08-2007 | 08:03 AM
imadot
Default Throttle trim hover advise
New to helis and have been told from the git-go to keep trim all the way down..as it don't use it. It seems so far in flying to obtain hover, stick placement hits the hover either too high or too low. Once I get an around hover height I will trim it in to the stick placement, useually it is almost half way up the trims setting, acheiving then a good hover. If trouble arises I try to cut off both throttle and trim at the same time. How do you all handle this? Can a switch on the CX2 TX cut off motors instead? Please advise.
Thank you!
