RE: Futaba 3PM-2.4G, do I need a failsafe?
Nitrothugg, thanks for the reply.
I'm still a bit curious why I can't use the HRS mode with the stock non-digital servos. When I was setting up the radio the stock servos seemd to work fine on the bench (although at this point I will strictly be using the PPM mode).
Is there any benefit to the digital servos? I do plan on a single servo conversion and was going to use a Hitec 5995 servo.
Thanks again.
Vince
