RE: TS2 POST IT HERE...
Jerry when the boat runs it goes exactly where you point it and shows no adverse effects of the list. I have a bit of negative trim on it while breaking it in so it does ride wet and even plowed the nose a bit turning in both directions. However, if you saw it run or were to drive it you would never know the list was there. It’s only noticeable when the boat is dead in the water. The prop is a thinned, sharpened, and balanced x440 two blade. I’m working on a three as we speak. No modifications on the blade shape as of yet. Chad.
