RE: Help in flying.
Radd's school of rotary flight. Google it. It will tell you the best way to go about learning to fly using just the heli. Personally I recomend a simulator to, realflight g3.5 is what I use, but if you don't want to spend another 200 bucks then I am sure someone can reccomend a good cheap sim. Radd's should be all you need, just take your time, follow it to the letter, don't cheat, and you should be flying in no time! There is a walkera forum under electric rc helicopters, you should find all the info you need on setup. You can also use the search function at the top of the page to look for stuff on your heli. Good luck. Peace.
