RE: CA protection
Use more yellow wood glue, it is way easier to use, sand and clean up. The only disadvantage is it takes much more time to cure, so you have to pin things together, but that also allows more working time.
I now use CA only when I need an instant cure, or for very specific applications where yellow glue is not a fit.
Yellow glue is also very inexpensive.
