The idlers pop apart with a screw driver, be careful and work your way around.
The drive sprockets are attached with a screw, the center hub will pop out again with the help of a screwdriver.
http://www.matotoys.com/canada/produ...products_id=87
Check out that link, at the bottom of the page there are some pictures that should help, good luck!!
