HL tiger sprockets
Old 04-09-2007 | 12:08 PM
dsketcher's Avatar
Default HL tiger sprockets
Has anyone tried stripping one down. Would like to see how it's constructed before I try anything.
Don
Old 04-09-2007 | 01:40 PM
Richard L.'s Avatar
My Feedback: (24)
Default RE: HL tiger sprockets
ORIGINAL: dsketcher
Please clarify "stripping one down".
Old 04-09-2007 | 02:03 PM
dsketcher's Avatar
disassembly, separating the two halves.
Old 04-09-2007 | 02:22 PM
The idlers pop apart with a screw driver, be careful and work your way around.
The drive sprockets are attached with a screw, the center hub will pop out again with the help of a screwdriver.
http://www.matotoys.com/canada/produ...products_id=87
Check out that link, at the bottom of the page there are some pictures that should help, good luck!!
Old 04-09-2007 | 02:36 PM
Richard L.'s Avatar
My Feedback: (24)
I like to use a small angled pick to pop out the center hub as the screwdriver will tend to mar the sprocket. The stock plastic drive sprocket is glued together pretty good, so I think it will be very difficult to separate it into two halves.
Old 04-09-2007 | 03:30 PM
Richard L.'s Avatar
My Feedback: (24)
If you plan to repaint the drive sprockets, then dipping them in a can of paint stripper for an hour or two might loosen up the glue that holds them together.
